    Dimensioning issues
    layout
    2 Posts 2 Posters 600 Views 2 Watching
    • J
      jerrymich
      I am new to LO and am having an issue. I just updated to SU2015 Pro. I have created the model, scenes, send to layout etc and have had no issues until I went back to SU, made some design changes. I then saved the file, went back to layout, updated the model reference and when I went to add the new dimensions, it would not let me do it. I had just erased the previous dimensions that were affected by the model changes. I can not enter dimensions or add a leader. I can add text. i have tried sending to back, send to front, etc., to no avail. Any thoughts?
      Thanks, Jerry
        Is it possible that the active layer in LO on which you're trying to place dimensions is lower in the stack than the one containing the SketchUp viewport? If that is the case, it isn't really that you can't add the dimensions and labels, you'r just doing it underneath the model so the viewport is masking them.
        Try turning off the visibility for the layer containing the SU viewport. You might find a bunch of dimensions and labels.
