    Models turn transparent with vector rendering
    layout
    6 Posts 2 Posters 845 Views 2 Watching
    • W Offline
      wmcswain
      Why does a model turn transparent with vector rendering in 2015, instead of staying solid? Does anyone know how to keep your model view solid while trying to render it with vectors?
      -Will
        We've seen reports of this in the past. The fix has always been to change OpenGL settings in SketchUp. Generally disabling Hardware Acceleration seems to fix it.
        • W Offline
          wmcswain
          I disabled the hardware acceleration, and it is still rendering it transparent. Anything else I should do?
            Did you try disabling Fast Feedback? Close SU and LO and then reopen. Rerender the viewports.
            • W Offline
              wmcswain
              YES ! THIS WORKED! Thank you!
                Excellent. I was off working on a physiological monitor and I got to wondering if by "transparent" you mean you could see background stuff in the LO file. But, as I assumed, it must have been that you were seeing a wireframe view of your model. Glad it's sorted.
