    SU 2015 and Bezier plug-in
    7 Posts 3 Posters 614 Views 3 Watching
    • J
      jimbojuliette
      I just downloaded SU 2015 and wanted to add the Bezier plug-in but the plug-in says it only goes to SU 2014. Does anyone know if it will work on SU 2015?
      Thanks,
      Jim
        It must work! πŸ˜‰
        SketchUp Compatibility:
        SketchUp 7, SketchUp 8, SketchUp 2013, SketchUp 2014, SketchUp 2015
        But careful : seems only for Windows! πŸ€“
        And TT_LibΒ² β€” 2.7.0 installaled! πŸ€“
        • BoxB
          You need to be more specific, 'The Bezier Plugin' could be one of several.
          The standard bezier curves certainly works.
          • J
            jimbojuliette
            It's the "BEZIER AND SPLINE CURVES: bezierspline.rb v1.2". I downloaded it into SU 2014 Make but the info sheet doesn't say it will work on SU 2015 Make.
            Jim
            • BoxB
              If you mean the one by Fredo6, download the latest version and it will work.
              All Fredo's plugins work with 2015
              http://sketchucation.com/pluginstore?pln=BezierSpline
              • J
                jimbojuliette
                That's the one.
                Thanks,
                Jim
                  Try also the Bezier Surface by Thomthom above, it's a true task! β˜€
