    Making rounded corners without a flat surface
    8 Posts 3 Posters 463 Views 3 Watching
    • G Offline
      gu5to
      Hi, I'm having trouble rounding the corners on this windowsill I'm trying to make. I can round the corners and push-pull it out, but then I haven't got a flat surface to apply my curve to. I'm sure there's an easy way to do this but I can't get my head around it!
      Cheers
        This is a job for Follow Me!!!! [Cue the super hero music]
        • G Offline
          gu5to
          Yeah I have tried follow me but I keep making a mess of it. Not sure what I'm missing
            I edited my post to include a quick screen shot. Does that look sort of like what you're after?
            • G Offline
              gu5to
              Yes it looks perfect. But how do I start off? Do I pull a rectangle out first?
                In that case I drew the profile and a path (the 3 lines above) and ran Follow Me to create the shape. You could draw the "board" and cut off the edges with profiles in much the same way you would do it to a real board with a router cutter. Follow Me can be additive as in my example or subtractive. It depends on what you want to start with.
                • BoxB Offline
                  Dave's got you sorted there but here's a couple of action shots to show how the path relates to the profile.
                  • G Offline
                    gu5to
                    Thanks so much to both of you. This has been very helpful.
                    Cheers
