    Street View Photo texture problem
    4 Posts 2 Posters 531 Views 2 Watching
    • A
      anadorian
      Based on a quick search of the forums, I did not see a solution to this problem. I am using Sketchup Make 2015 on mac osx, I have the newest update of SU, the newest flash player, and have cleared all my browser chaches.
      When I select the face of an object to add a photo texture from streetview, the window pops up normally, and shows the correct geolocation, when I go to select a region, however, the preview turns bright magenta! I can see and manipulate the selection rectangle, but the image preview underneath is lost.
      If i create an arbitrary polygon, and select the region it will show up properly on the face, I simply cant control what is being sampled for a region because of the magenta color obscuring the preview.
      see example below:
      http://i61.tinypic.com/20kbqq9.png
      http://i60.tinypic.com/j15abt.png
      • D
        driven
        happening here as well...
        there's an error in the css code which Trimble will need to fix...
        I got it to work by adding an opacity setting...
        #tweaker-embed {
        	opacity; .5;
          width; 100%;
          height; 100%
        unless you know how to add it yourself, I can't see an easy way to share...
        I'll report it
        john
        • D
          driven
          hi
          this is working for me now...
          i did report it but had no reply, however it's working again...
          it may be the latest Yosemite security update fixed it...
          not sure...
          john
          • A
            anadorian
            Thanks everyone, this seems to have been resolved.
