    Street View Photo texture problem
    4 Posts 2 Posters 381 Views 2 Watching
      anadorian
      Based on a quick search of the forums, I did not see a solution to this problem. I am using Sketchup Make 2015 on mac osx, I have the newest update of SU, the newest flash player, and have cleared all my browser chaches.
      When I select the face of an object to add a photo texture from streetview, the window pops up normally, and shows the correct geolocation, when I go to select a region, however, the preview turns bright magenta! I can see and manipulate the selection rectangle, but the image preview underneath is lost.
      If i create an arbitrary polygon, and select the region it will show up properly on the face, I simply cant control what is being sampled for a region because of the magenta color obscuring the preview.
      see example below:
      http://i61.tinypic.com/20kbqq9.png
      http://i60.tinypic.com/j15abt.png
        driven
        happening here as well...
        there's an error in the css code which Trimble will need to fix...
        I got it to work by adding an opacity setting...
        #tweaker-embed {
        	opacity; .5;
          width; 100%;
          height; 100%
        unless you know how to add it yourself, I can't see an easy way to share...
        I'll report it
          driven
          hi
          this is working for me now...
          i did report it but had no reply, however it's working again...
          it may be the latest Yosemite security update fixed it...
          not sure...
            anadorian
            Thanks everyone, this seems to have been resolved.
