    [req] Exterior lighting advice
    renderpluginsextensions
    4 Posts 3 Posters 446 Views 3 Watching
    • john2J Offline
      john2
      I want to show bollards in exterior lighting for a park I am designing. Which is the best suited vray light for showing such lightings?
      Also correct me if I am wrong
      Strip lights = vray rectangular lights
      For lamp posts = vray spot lights/IES lights
      Accent lights = IES lights
      all the rectangular lights here.
      How should I make such lights? Make a 2d dotted pattern in autocad and then apply emissive layers yeah?
      Here in this image all the IES lights near the wooden steps
        rspierenburg
        I suppose it would depend on the bollard. You could just use a sphere light inside the bollard component, or if it was a bollard with down-lighting I would use an IES light. Some manufacturers might even list IES information for their lit bollards.
        Rob
        • john2J Offline
          john2
          and what about the Studio-Roosegaarde-Solar-Bike-Path-Van-Gog image? How is that made in vray? too many lights?
          • andybotA Offline
            andybot
            That should be pretty simple to do with an emmissive material. Once you have an image of the pattern, just stick it in an emmissive layer. Make sure anything that's not lit is pure black, or else you may end up with some undesired glow. (you could mask the emmissive layer to make sure that doesn't happen.)
