    Don't want notification for makefaces
    6 Posts 3 Posters 463 Views 3 Watching
    • john2J Offline
      john2
      While using the makefaces plugin, I get notifcation about the stats upon completion of the command. I have to press ok everytyime which I find irritating. Can I tweakt the rb file so that this popup doesn't come and the command is done quickly?
        There are several other [newer] face making scripts, which don't have that report popping up at the end...
        But, if you want to stick with Todd Burch's version... edit the file makefaces.rb with Notepad.exe, or a similar plain-text editor [not a wordprocessor]: add # in front of the offending code - i.e. the line starting UI.messagebox...., save it and restart SketchUp...
        No more dialog !
        • BoxB Offline
          Personally I use one by an obscure plugin author called Add faces http://sketchucation.com/pluginstore?pln=addfaces
          • john2J Offline
            john2
            I added # before two lines having that ui messagebox
            Now when I start sketchup I get this error
            Error Loading File makefaces.rb
            Error: #<SyntaxError: C:/Users/ArchitectFella/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/makefaces.rb:158: syntax error, unexpected ',', expecting keyword_end
            ...\nThe process lasted: "<< elap, MB_MULTILINE, "Make Faces St...
            C:/Users/ArchitectFella/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/makefaces.rb:158: dynamic constant assignment
            ...lasted: "<< elap, MB_MULTILINE, "Make Faces Statistics")
            C:/Users/ArchitectFella/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/makefaces.rb:158: syntax error, unexpected ')', expecting :: or '[' or '.'
            ...ILINE, "Make Faces Statistics")
            C:/Users/ArchitectFella/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/makefaces.rb:164: syntax error, unexpected end-of-input, expecting keyword_end>
              @Box
              I don't like 'to blow my own trumpet' [too much!] πŸ˜‰
              [meine eigene Posaune blasen ?? auf die Pauke hauen ??]
              @john2
              Sorry about that... the odd way Todd set up his string is "multi-line"...
              So # rem out the second messagebox's lines like this:
              #UI.messagebox("makefaces.rb; Copyright 2004-2006 Burchwood USA."        <<
                                #"\nVersion 1.2   May 14,2006."                    <<
                                #"\n\nThere were " << total_items.to_s << " selected items."   <<
                                #"\n\nThere were " << notAnEdge.to_s << " non-Edge selected items."   <<
                                #"\nThere were " << (total_items-notAnEdge).to_s << " Edges selected."   <<
                                #"\n\nThere were " << x.to_s << " face(s) added."       <<
                                #"\nThe process lasted; "<< elap, MB_MULTILINE, "Make Faces Statistics")
              • john2J Offline
                john2
                Thanks for advising me a great plugin by TIG sir. πŸ‘ πŸ˜„ Thanks for the trumpet πŸ˜† . That plugin of TIG sir is way much better and doesn't blow the trumpet of notification about how many faces were made, lines, stats and all the useless stuff for ordinary user like me. πŸ‘ πŸ‘ πŸ˜†
