    Viewing Coordinates - Again
    3 Posts 2 Posters 267 Views 2 Watching
      seasdes
      I frequently need to view the coordinates of different parts of a model.
      Now there was a similar post this year that asked this same question (http://sketchucation.com/forums/viewtopic.php?f=79%26amp;t=59051%26amp;p=537394%26amp;hilit=coordinates#p537394). The advice given was to use the Text tool and select a point. This works as long as you are inside a group or component. If you are not inside a group or component the name of the group or component is displayed.
      Is there a way to view a coordinate without having to enter the group or component. Or better still is there a plugin that works with SU Pro 2015.
      Using Sketchup Pro 2019
      • fredo6F Offline
        fredo6
        You can use AngleInspector, part of FredoTools, which displays world coordinates of points (and other info), at any level of the model.
        Fredo
          seasdes
          Thanks Fredo
