    How do I install the Helic Along Curve plugin?
    4 Posts 3 Posters 966 Views 3 Watching
      LARV
      I found the Helix along curve plugin. For some reason it´s not in the plugin library so I had to download it from the creators page, here: http://3dalbertsoft.wordpress.com/plugins/
      I have dropped other plugins in the correct sketchup folder previously, but this one is not a single .rb file. It contains several, with one placed inside a seperate folder when downloading the plugin.
      I tried selecting all three and dropping them in the plugin folder, but it didn´t (as I suspected) work. I get an error message when opening Sketchup.
      How should I go about this?
      Thanks!
      • massimoM Offline
        massimo Moderator
        Unzip the folder, then put the .RB file & the folder (exactly like you see in the image) in the plugins folder.
        Tried it quite quickly, but it seems to work like a charm in SU 2014.
          LARV
          [attachment=0:2ztz9dl5]<!-- ia0 -->Cattura.JPG<!-- ia0 -->[/attachment:2ztz9dl5]
          Do you know what you are? A pro.
          It worked.
          • BoxB Offline
            For future reference, If you get a .zip you can rename the .zip to .rbz and install it using the Install Extension button in Preferences.
