    Is it possible to generate this over terrain?
    10 Posts 6 Posters 603 Views 6 Watching
      LARV
      I created this using the PathCopy plugin. How would I go about making this follow a terrain with elevation?
      • bazB Offline
        baz
        There are a couple of plugins which will 'Drop' entities to nearest etc, can't remember what they are are called. Do a search for 'drop'.
        Or wait til someone else replies with more info.
        • jeff hammondJ Offline
          jeff hammond
          i use one calledDropGC by the smustard team available at trimble extension warehouse.. it drops objects straight down and the stop when intersecting with other geometry.. i think there are other versions which will drop down then orient objects according the the angle of the terrain.
          dotdotdot
          • cottyC Offline
            cotty
            Example with ThrowTo...
            (no orientation according the angle of the terrain)
            my SketchUp gallery
            • srxS Offline
              srx
              I never used it, but maybe you can for this purpose - SketchyPhysics.
              www.saurus.rs
                LARV
                I drew a line on a terrain with the surface pen tool, selected the line, copied it and used weld. Then PathCopy.
                The result wasn´t perfect, but I can see myself using that technique. Details that are off could be fixed manually I suppose.
                • bazB Offline
                  baz
                  Looks pretty good to me.
                  (Only the gods achieve perfection, whilst we mortals merely strive for it).
                    LARV
                    Thanks. It´s a start.
                    Actually, I tried this out some more and you can get really far using that technique. I never work with machine like perfection anyway. Like CAD-drawings etc.
                      RayTracer by Thomthom
                      Despite of the name, it's a strong falling objects on the ground! 😉
                      http://sketchucation.com/forums/download/file.php?id=53900&t=1
                        LARV
                        JESUS CHRIST!! Seriously, some of these plugins are so great I can´t control myself.
                        Thank you
