    Maxwell Sea?
    extensions
    5 Posts 2 Posters 2.2k Views 2 Watching
    • C
      chrisplym
      Hi everyone!
      Sorry for posting a rendering question in this part of the forum - but its to do with Maxwell... not VRAY or Thea.
      Can anyone tell me whether the Maxwell Sea function is meant to work in Sketchup (i.e. when I render a static image) or instead will it only work when used in conjunction with Realflow? I am using SU2014 (make) and Maxwell v3 (purchased, not free).
      Many thanks for any advice πŸ˜„ sorry if its a simple question/answer, but im fairly new to rendering!
      Chris
      • jason_marantoJ
        jason_maranto
        Yes, you can use this feature with RealFlow -- The relevant support information can be found here:
        http://support.nextlimit.com/display/mxdocsv3/SketchUp+Extensions
        and here:
        http://support.nextlimit.com/display/mxdocsv3/Maxwell+Sea
        • C
          chrisplym
          and here:
          Hi Jason, thank you for the reply - but I am still unclear...
          Will it work in just SU as a still render using Maxwell, or is the ONLY way it will work to use RealFlow?
          Many thanks and kind regards
          Chris
          • jason_marantoJ
            jason_maranto
            With or without -- however it should be obvious that without Realflow some of the things that could make a more realistic sea (like foam maps and sea spray) will not be possible. Maxwell sea simply does the waves as you can see clearly in the documentation I linked.
            • C
              chrisplym
              You're right - it is "obvious", however I am happy with this; thank you for your help.
              kind regards
              Chris
