    [Plugin] TIG-layer_material_tools
    6 Posts 4 Posters 4.9k Views 4 Watching
      I have updated my own brand-new version of Didier's toolset, which:
      Make Materials from Layers and Layers from Materials, and Set Materials from Layers and Layers from Materials.
      Version 1.0 is now available from the PluginStore.
      http://sketchucation.com/pluginstore?pln=TIG_layer_material_tools
        thelorax
        TIG,
        I just wanted to thank you personally for this script. Trimble removed the (use color by layer materials) option from the 3ds export dialog, which breaks a method I've used for moving files between sketchup and max for years now. your script is the only way now to get the layer info into max. I don't know ruby, but I wrote a pretty sweet maxscript for exchanging files between sketchup and max. If you use max let me know.
        https://www.djc.com/stories/images/20140912/Block_48_NE_web.jpg
        thanks!
        chris
          Repsaj1975
          Hi TIG,
          This plugin worked fine in SketchUp2017 but in SketchUp2018 it isn't working anymore
          Using it to import a dwg
          Then making materials from layers
          And finally set materials from layer names
          Is there al solution?
            This is an old plugin.
            Can you explain how it is 'not working' ?
            Errors loading ?
            Errors when running ?
            If you run it with the Ruby Console open do you see error messages ? etc...
            Please give full details...
            It works fine for me...
              JanaVS
              Errors loading ?
              Hello,
              I uploaded 2 documents that show in detail how is this plugin working in 2017 version and not working in 2018 version. This is exact the same model that I tested on.
              I practically do the same thing in both cases only the results are different.
              If you have any idea how can I make this work, please let me know.
              Thank you!
              Sketch up 2017.pdf
              Sketch up 2018.pdf
                It seems to report the changes the same in both versions ?
                So can you check the materials actually get made in the 'failing' model.
                Also can you check in it, what material should be associated with an object on a layer - and what Entity Info says it has...
                What are your View / Style settings ?
                Are there differences between these in the two SketchUp versions ?
                Can you post an example SKP that I can test...
                You didn't seem to run it with the Ruby Console open ?
                Any error messages ?
