    What is the plug in that divides
    6 Posts 3 Posters 516 Views 3 Watching
      Ands43
      arcs, lines, circles and leaves a small cross, I have an oval shape that needs one section of it dividing into 3
      • cottyC Offline
        cotty
        I think your question is not clear enough. Do you have an image?
        my SketchUp gallery
          Ands43
          So it's going to be a bar/serving area with one open end. I want the 2 opposing halves to be divided equally into 3 pieces with the segment opposite the entrance the same size as the entrance. Perhaps the image will make this clearer. Maybe it was in credo tools or sub divide and ???
          • cottyC Offline
            cotty
            one way with basic tools...
            [screenr:1azeztzl]nThN[/screenr:1azeztzl]
            my SketchUp gallery
            • jeff hammondJ Offline
              jeff hammond
              this isn't exactly what you're asking about but personally, i feel it's the better way to go about it in sketchup since you end up with better vertex placement.. it uses fredo's bezier spline plugin:
              http://sketchucation.com/forums/viewtopic.php?t=13563
              the guide lines portion are simply a means to illustrate what's happening.. not a necessary step though.
              1. truncated elliptical shape.
              2. with BezierSpline installed, right click on the curve then BZ-convert to -> Polyline Segmentor .. in this example, i divided into 42 segments (7 sections of 6 equal segments)
              3. offset/extrude/etc.. since the segments of the curve are all equally spaced now, you can count segment and do your dividing on the curve vertices.. (example shows every 6th segment being divided)
              dotdotdot
                Ands43
                Yes that's the one I meant, freddo tools.
                Although Cotto's way will work just fine. Thanks chaps
