    Selected Dim to Component Instance
    4 Posts 3 Posters 471 Views 3 Watching
    • K Offline
      ktkoh
      I am starting with the following code (after selecting a dim in the model)
      mod = Sketchup.active_model # Open model
      ent = mod.entities # All entities in model
      sel = mod.selection # Current selection
      s_ent = sel[0]
      type = s_ent.typename
      if type == "DimensionLinear"
         arr = s_ent.start
      if arr[0].nil?
        UI.messagebox("No attached entity. Point is " + arr[1].to_s)
       else
         UI.messagebox("Attached entity; " + arr[0].to_s)
        type = arr[0].typename
        parent1 = arr[0].parent
        l_name = parent1.layer.name
      This gets me to the Component Definition but I need the Component Instance to find the layer name so I can change the dim layer to the Component Instance layer.
      Keith
      • sdmitchS Offline
        sdmitch
        > s_ent = sel[0]
        >    arr = s_ent.start
        > if arr[0].nil?
        >  else
        >  end
        > end
        Keith
        ent = mod.active_entities
        sel = mod.selection
        s_ent = sel[0]
         arr = s_ent.start
         if arr[0].parent.is_a?(Sketchup;;ComponentDefinition)
          parent1 = arr[0].parent;
          parent1.instances.each{|ci|
           if ci.bounds.contains?(arr[1])
            l_name = ci.layer.name;
            s_ent.layer=l_name;
            sel.add ci;break
         else
          puts "Dimension not associated with component"
        http://sdmitch.blogspot.com/
          Couple of pointers.
          I think you really want:
          mod.**active_**entities # All entities in **active context**
          NOT the entities in the model itself: after all, the user might be inside an edit ?
          You might also like to check Sketchup.version and/or if a particular method is defined [ .respond?] because dim's were added to the API quite recently...
          ... arr = s_ent.start ### the array of data that the dim is attached to [at its start] ... parent1 = arr[0].parent ### the vertex inside the definition l_name = parent1.layer.name ### the definition itself won't have a layer ?
          You have no simple way of knowing the instance from the definition.
          if the parent1.instances.length==1
          instance = parent1.instances[0]
          BUT if not, then you need to find how to spot the instance...
          We have a point at the end of the dim...
          pt = arr[1]
          You can get its screen xy thus:
          view = mod.active_view xy = view.screen_coords(pt) x=xy[0] y=xy[1]
          Now set up a pickhelper to test it...
          ph = view.pick_helper ph.do_pick(x, y) array = ph.all_picked
          returns an array of all things at that point, including instance[s], so iterate through the array.uniq and test if its an instance AND it matches arr[0] == instance.definition
          If so then you have your instance !
          Get the layer from that etc...
          πŸ˜•
          • K Offline
            ktkoh
            Thanks for the help. I'll try your suggestions.
            Keith
