    Linear Footage of Crown Molding
    3 Posts 3 Posters 430 Views 3 Watching
    • A
      aceoftrades
      I am looking for a way to have Sketchup calculate the linear footage of crown molding, toe kick, etc in kitchen models I make and include in Generate Report. Any suggestions? Thanks in advance.
      • KrisidiousK
        Krisidious
        Profile Builder Pro... built it part of plugin.
        By: Kristoff Rand
        • S
          slbaumgartner
          Generate Report just prints out the attributes you have attached to Components in your model, it does not do math. To report calculated values such as summed lengths of Components that are labelled a particular way, you will need to create a custom Ruby script. There is info about how to do so using attributes here:
          http://www.sketchup.com/intl/en/developer/docs/tutorial_attrreporting
          Alternatively, you could generate a report in spreadsheet form and do your own calculations there. You could also get a spreadsheet from the CutList plugin.
          Or, as Kris points out, there are several kitchen design extensions/plugins that might do the work for you. There are two aspects that might be downsides depending on your desires: many of them are not free, and you usually have to do the entire project within their system.
