    Geometry problem importing 3D DWG file to Skp
    7 Posts 3 Posters 646 Views 3 Watching
      bizkonson
      Im importing a not so big 3D DWG file into sketchup.
      the imported model starts to "flicker" when i zoom in
      and the worst part of it is sketchup cant lock on to end points of the geometry.
      im using sketchup 14 on windows 7 pro
      my computer is I7 3770k running at 4550, 16gb ram and Gforce gt760 gpu.
      its not a GPU problem since all other even larger models work fine.
      i tried using 3dmax as a mid way for the dwg file.
      but 3ds and obj resulted in same geometry problem.
      im including the dwg file.
      any help or advice would be highly appreciated.
      GROUND.dwg
      • BoxB Offline
        Can't look at the file but it sounds like a clipping plane issue created by the origin of the DWG being a long way from the SU origin.
          It looks something like this?
          You're seeing Z-fighting due to surfaces being too close together for the OpenGL and your graphics card to resolve.
            bizkonson
            [attachment=0:24fxfyjb]<!-- ia0 -->2014-11-12_13-02-42.png<!-- ia0 -->[/attachment:24fxfyjb]
            You are wrong it has nothing to do with the GPU.
            ive had models imported from 3dmax that were even closer.
            and ive built models with details smaller then a mm.
            so its not the GPU.
            i belive the problem is due to Autocad having a different system for understanding endpoints. and non of the skp plug-in importers can resolve it.
            • BoxB Offline
              It is a clipping plane issue, which is a graphics issue.
              It could be several things.
              The layers you have left in the .dwg
              it could be the origin of one of the many groups
              a combination of both
              something else
              I exploded the whole model and your issue goes away, which suggest to me it is a CAD origin problem.
              Edit: I just imported your drawing retaining the origin, which you can choose in the import options, and it shows the model 693136.411m from the origin. A known clipping issue.
              • BoxB Offline
                And as you can see here, by correcting the origin your GPU issue goes away. No Z-fighting or clipping plane.
                  bizkonson
                  thanks box!
                  i actually solved it yesterday night as well by copying it to another file and exploding and regrouping.
