    Grasshopper to SketchUp?
    extensions
    7 Posts 5 Posters 3.5k Views 5 Watching
    • KrisidiousK Offline
      Krisidious
      Is it real?
      By: Kristoff Rand
        driven
        looks like it's a SU import plugin that imports live updates from Rhino...
        doesn't appear to be a two way street...
        john
        • jeff hammondJ Offline
          jeff hammond
          i don't get it
          you have to use rhino & grasshopper anyway so why wouldn't you just do everything in rhino in the first place.. then export out to sketchup when you're done if need be.
          (like- what's the reasoning/advantage with updating the sketchup model after every rhino operation?)
          dotdotdot
            Krisidious
            I have no idea...
            By: Kristoff Rand
            • jolranJ Offline
              jolran
              I have to dito Jeff.
              If I remember correctly there was a topic where Tig and Thomthom helped this guy making the .rb import geometry with the help of a timer. So that's how it works (?).
              Maybe there are some extra precautions for getting viable geometry in Sketchup,
              and positioning the geometry ?
              Also if it does becomes a "2 way street", this plugin could be very useful for Rhino-users,
              importing Sketchup geometry on the fly..
              I don't own Rhino so I can't test...
              FYI. I'm still working on a Sketchup integrated solution on a daily basis. πŸ˜„
              Nothing fancy as Grasshopper of course..
              (no timetable set)
              • PixeroP Offline
                Pixero
                I believe the demo lets you save a rhino project 15 times but the Grasshopper plugin saves grasshopper "scripts" in its own file format apart from those rhino saves so you can test it.
                • jolranJ Offline
                  jolran
                  I dident know that! Good information, thanks.
