LibFredo6.3 and "non-asciii" name/ Roundcorner
Running the latest version of Sketchup 2014 on a Mac.
Firstly haven't been able to run Round Corners for a few months despite multiple attempts to download it. It simply doesnt load. I used to use it.
Secondly I want to make sure I have latest LibFredo 6.3, but no idea what "non-asciii" name means and if I am out of luck. Either way I can't seem to get the latest up and running. My needs are simple, I run a few plugins but always run into these irritating problems with plugins.
I use Ext Warehouse but Lib Fredo is apparently out of date there.
I know how to load plugins directly into my plugins library myself also.
Thanks in advance! -
@cquinn said:
Thanks in advance!Non-ascii is simply a reference to accentuated characters, cyrillic, etc... Release 6.3 is mainly to address some issues for username with such characters (since SU14 stores plugins in a direct folder ory Under the Users directory on Windows). Normally, Mac should not be concerned.
I recommend you install from the Sketchucation Plugin Store, which is simply one click.
Unfortunately publishing on the Extension Warehouse takes longer because there is a formal review by the Sketchup team. So version 6.3 (and by the way version 6.2) were submitted but are not yet published officially on EWH, pending this review.
Now, if you have a problem of installation, try to explain what it is if you want anyone here on SCF to help.
Fredo
Register LoginAdvertisement
