    Plugin and Shortcut issue [SOLVED]
    3 Posts 2 Posters 248 Views 2 Watching
      MrWip
      Hi all,
      I'm working constantly with Didier Bur " extrude line along a vector", but for some reason, this tool does not show in the shortcut list in sketchup, making it hard to use in a quick worflow
      On Sketchup 8, I've found an old plugin toolbox, called SCF power toolbar, containing this extrude line tool, and having an entry in the shortcut list, so, everything was fine...
      Sadly, switching now to Sketchup 2014, I realize that this old power toolbar is not supported anymore, and that the latest version of the plugin still does not have an entry in the shortcut list.
      So here is my question : Is there a way to add a plugin to the shortcut list ? does it have to be coded in the ruby file itself ? does anyone have been encountering the same issue (on this plugin or another) and found a solution ?
      Thank you in advance
      http://www.wip-archi.com
        Are you using the latest version of this RB ?
        http://sketchucation.com/pluginstore?pln=extrudelinetool-Modified-TIG
        gives you the RB inside an RBZ which is easily installed.***
        This version has a Plugins menu item and that is listed in the Preferences > Shortcuts panel, filter with 'extr' to give a shortened list which includes it.
        ***If you have an older version with a different RB file name then remember to remove that from your Plugins folder, so the newer one is used...
        If you are referring to the Projections toolbar equivalent that has no menu items to shortcut to.
        But I have a version which adds a Tools submenu, which can then take shortcuts...
        I can PM that to you if so...
          MrWip
          TIG,
          Thank you very much, first, for the very quick feedback, and second, for the solution, it works perfectly now 😄
          ... I'm always amazed by the efficiency of the community support here on Sketchucation. It's a great pleasure to know that such a place exists.
          Thanks again !
