    How to get face which is belong to two group
    9 Posts 4 Posters 965 Views 4 Watching
    • Y
      YoungOSG
      there are two groups .i wanna to get the face ,which is belong to two groups.just like two walls,there is a face which can be think to belong any wall.
      as the picture.
      how can i can get the face?
      thanks
      • cottyC
        cotty
        If there is one face (in one of the groups) or if there are two faces (one in each group) depends on the way you created the groups. You can always enter one group, copy the face to the clipboard and paste (in place) it outside those groups to get a single face independent of the groups.
        my SketchUp gallery
        • K
          kaas
          Almost the same answer as Cotty above (posted while I was typing):
          Think of a group as a container or a room in a house. An object can't be in two containers / rooms at the same time - it can only be in one container / room / group at the same time.
          So, you have several options:
          1. make a copy of 'the face' and put them in both groups
          2. make an extra third group and put 'the face' in it. Now it doesn't belong to either groups but is a unique group itself.
            3)...
          The best choice depends on what you're trying to achieve.
          • Y
            YoungOSG
            i think i don't explain it clearly. there are two faces (one in each group),as you say. and when i explode two groups,i can get 11 faces which 1 face is delete.
            i wanna use api to get this face in groupA which in groupB also has this face .i mean they are occupy same region.but they are different.
            can i do it by judge face's vertices position or some other ways?
            • cottyC
              cotty
              So this is a ruby question? I've moved this topic...
              my SketchUp gallery
              • TIGT
                Get
                tr1=group1.transformation
                tr2=group2.transformation
                You need those th apply to things later...
                The two 'coincident' faces in question will have some similar properties [when adjusted for their container's transformation].
                You need to iterate the faces in group1 to get a suitable in group2
                faces1=group1.entities.grep(Sketchup;;Face)
                faces2=group2.entities.grep(Sketchup;;Face)
                face2=nil
                face1=nil
                faces1.each{|face|
                  min=face.bounds.min.transform(tr1)
                  max=face.bounds.max.transform(tr1)
                  norm=face.normal.max.transform(tr1)
                  faces2.each{|f|
                    if f.bounds.min.transform(tr2)==min && f.bounds.max.transform(tr2)==max && f.normal.transform(tr2)==norm.reverse
                      face2=f
                      face1=face
                      break
                  break if face2
                ### face2 is the matching face in group2, if not nil !  Delete it !
                ### face1 is the matching face in group1
                This is NOT foolproof.
                BUT you can add extra tests...
                For example... collect the loops of face2, collect their vertices as points and transform them, then compare with the loop-vertices-points-transformed of face1, if there are any mismatches then the two faces are NOT completely coincident - e.g. one of the otherwise coincident could have a side-notch or a hole in it, but still have the same normal and bounds !
                You need to make these decisions... Simple boxes ?
                • Y
                  YoungOSG
                  @tig said:
                  Get
                  > face2=nil
                  > face1=nil
                  > faces1.each{|face|
                  >   faces2.each{|f|
                  >       face2=f
                  >       face1=face
                  >       break
                  >     end
                  >   break if face2
                  thanks! you always be the super star 😍
                  • Y
                    YoungOSG
                    @tig said:
                    Get
                    > face2=nil
                    > face1=nil
                    > faces1.each{|face|
                    >   faces2.each{|f|
                    >       face2=f
                    >       face1=face
                    >       break
                    >     end
                    >   break if face2
                    one more question.if there are many groups,how can i get the groupA which is adjacent with groupB.
                    i intend to judge by distance.is there any easy way to do this?
                    • TIGT
                      Try the groups' .bounds if they 'touch', then some_group.bounds.max.x OR .y OR .z and some_other_group.bounds.min.x OR .y OR .z might be coincident ??
                      Especially if the are simple boxes...
