    Need some help again.
    3 Posts 2 Posters 469 Views 2 Watching
    • S
      Skastafari
      A few months ago, Tig helped me with some syntax for exploding walls in my model grouped by name, The specific line of code was:
      Sketchup.active_model.active_entities.grep(Sketchup;;Group).each{|e| e.explode if e.name=~/^[Ww]all/ }
      I now have to explode components by the same naming system, starting with 'wall'.
      I was thinking I could add another line to the module and simply switch (Sketchup::Group) with (Sketchup::ComponentInstance) and everything should work fine... but it does not. I found myself frustrated again and decided to come back to the pros and ask for some help here.
      • TIGT
        Unless the Instance itself is named 'wall' it needs to refer to the Definition thus:
        Sketchup.active_model.active_entities.grep(Sketchup;;ComponentInstance).each{|e| e.explode if e.definition.name=~/^[Ww]all/ }
        However, to delete Instances which are themselves named 'wall' use
        Sketchup.active_model.active_entities.grep(Sketchup;;ComponentInstance).each{|e| e.explode if e.name=~/^[Ww]all/ }
        • S
          Skastafari
          Thanks again TIG! I am very grateful. I knew I was missing something, but was pretty much stumped. Thanks for putting me back on track, and so quickly. Cheers
