    Need some help again.
    3 Posts 2 Posters 408 Views 2 Watching
      Skastafari
      A few months ago, Tig helped me with some syntax for exploding walls in my model grouped by name, The specific line of code was:
      Sketchup.active_model.active_entities.grep(Sketchup;;Group).each{|e| e.explode if e.name=~/^[Ww]all/ }
      I now have to explode components by the same naming system, starting with 'wall'.
      I was thinking I could add another line to the module and simply switch (Sketchup::Group) with (Sketchup::ComponentInstance) and everything should work fine... but it does not. I found myself frustrated again and decided to come back to the pros and ask for some help here.
        Unless the Instance itself is named 'wall' it needs to refer to the Definition thus:
        Sketchup.active_model.active_entities.grep(Sketchup;;ComponentInstance).each{|e| e.explode if e.definition.name=~/^[Ww]all/ }
        However, to delete Instances which are themselves named 'wall' use
        Sketchup.active_model.active_entities.grep(Sketchup;;ComponentInstance).each{|e| e.explode if e.name=~/^[Ww]all/ }
          Skastafari
          Thanks again TIG! I am very grateful. I knew I was missing something, but was pretty much stumped. Thanks for putting me back on track, and so quickly. Cheers
