    Problem with section plane
    13 Posts 4 Posters 763 Views 4 Watching
    • U Offline
      ukash
      Hi there,
      I hope you can help me with my problem.
      every time i trying to use section plane is becoming really big far beyond my model.
      it is really annoying when i am trying to create some views.
      do you know what could be the reason for it??
      • BoxB Offline
        It sounds like you must have some geometry off in the distance. You need to find that and get rid of it, it could just be a tiny line fragment.
        • U Offline
          ukash
          I have looked for it. didn't find anything
          • cottyC Offline
            cotty
            You can upload an example here so that we can find the reason ...
            my SketchUp gallery
            • BoxB Offline
              If you go Zoom Extents does your model become very small?
              • KrisidiousK Offline
                Krisidious
                make sure to use show hidden geometry before zoom extents.
                By: Kristoff Rand
                • U Offline
                  ukash
                  I am not sure how to upload picture on here
                  • U Offline
                    ukash
                    every time i use section plane tool it changes size too
                    • U Offline
                      ukash
                      [img]Screen%20Shot%202014-10-16%20at%2014.33.08.png%20=>%20The%20image%20must%20be%20at%20least%200%20pixels%20wide,%200%20pixels%20high%20and%20at%20most%201600%20pixels%20wide%20and%201600%20pixels%20high.%20The%20submitted%20image%20is%202560%20pixels%20wide%20and%201440%20pixels%20high.[/img]
                      • U Offline
                        ukash
                        • BoxB Offline
                          Below the message box when you are writing your reply is an upload section.
                          One way to find and remove loose geometry is to Hit CTRL A which will select everything in the model, then while holding shift draw a selection box from left to right around the part of the model you know you want, this deselects that part and keeps anything outside that selected, now hit Delete and anything off in the distance should be removed.
                          • U Offline
                            ukash
                            It did not help that either.
                            • BoxB Offline
                              Using the Upload Attachment can you upload the actual model if it isn't too big?
