    Problem with section plane
    13 Posts 4 Posters 886 Views 4 Watching
    • BoxB
      It sounds like you must have some geometry off in the distance. You need to find that and get rid of it, it could just be a tiny line fragment.
      • U
        ukash
        I have looked for it. didn't find anything
        • cottyC
          cotty
          You can upload an example here so that we can find the reason ...
          my SketchUp gallery
          • BoxB
            If you go Zoom Extents does your model become very small?
            • KrisidiousK
              Krisidious
              make sure to use show hidden geometry before zoom extents.
              By: Kristoff Rand
              • U
                ukash
                I am not sure how to upload picture on here
                • U
                  ukash
                  every time i use section plane tool it changes size too
                  • U
                    ukash
                    [img]Screen%20Shot%202014-10-16%20at%2014.33.08.png%20=>%20The%20image%20must%20be%20at%20least%200%20pixels%20wide,%200%20pixels%20high%20and%20at%20most%201600%20pixels%20wide%20and%201600%20pixels%20high.%20The%20submitted%20image%20is%202560%20pixels%20wide%20and%201440%20pixels%20high.[/img]
                    • U
                      ukash
                      • BoxB
                        Below the message box when you are writing your reply is an upload section.
                        One way to find and remove loose geometry is to Hit CTRL A which will select everything in the model, then while holding shift draw a selection box from left to right around the part of the model you know you want, this deselects that part and keeps anything outside that selected, now hit Delete and anything off in the distance should be removed.
                        • U
                          ukash
                          It did not help that either.
                          • BoxB
                            Using the Upload Attachment can you upload the actual model if it isn't too big?
