    Loft Bedroom WIP
    13 Posts 6 Posters 937 Views 6 Watching
    • AdamBA Offline
      AdamB
      3 minute render at 3840x2160 resolution.
      SketchUp 2014 + LightUp v4.1
      • DanielD Offline
        Daniel
        Looks great, Adam, but your wood grain is running in the wrong direction on some parts of the two bookcases. It really stands out on the side of the bookcase on the left.
        My avatar is an anachronism.
        • andybotA Offline
          andybot
          I'm curious about the reflections in LightUp - is there any way to reduce the glossiness of the reflections, or is it only possible to reduce the intensity of the reflections?
          • olisheaO Offline
            olishea
            Floor looks way too glossy but this could be a killer scene! Have I seen this rendered somewhere else before? I'm sure I've seen this model before, but maybe i'm wrong.
            oli
              There's a roughness setting that controls glossiness
              • AdamBA Offline
                AdamB
                Here's a quick video covering some setup for polished floors.
                And a couple new stills with fixed wood grain and reduced floor polish. Thanks for the feedback.
                http://i614.photobucket.com/albums/tt229/ElektraGlide/loftbed_basic_lightupScene2_2014-10-14_0919_zpsa7e013ec.jpg
                http://i614.photobucket.com/albums/tt229/ElektraGlide/loftbed_basic_lightupRafters_2014-10-14_0921_zpsf6d765ba.jpg
                • andybotA Offline
                  andybot
                  wow Adam, that looks really great! Those controls are quite comprehensive. πŸ‘
                  • pbacotP Offline
                    Nice work. Like the video too. I have one question on this render. the ceiling appears to be floating above the trusses, and this appears more pronounced on a couple "boards". What's causing that?
                      http://tapatalk.imageshack.com/v2/14/10/14/67f36e0499113d312ce752e599df54b8.jpg
                      @peter
                      Are you referring to the back left corner where the ambient occlusion is more pronounced in two areas.
                      • pbacotP Offline
                        The (AO?) shading of the ceiling at most of the trusses makes it look like it is floating an inch above the trusses instead of sitting on them. See the second truss in. Maybe it is the lack of the same AO on the trusses themselves.
                        • AdamBA Offline
                          AdamB
                          I used the floor plugin to build the timber siding but SketchUp appears to have eaten a triangle there. 😞
                          One thing is that raytracers tend to have quite aggressive AO cutoff by default - a few inches away from the surface and its full white - whereas LightUp defaults to a few feet.
                          Using the Custom cutoff distance, you get quite different results. These AO with no color bleed ('clay render') using increasingly large cutoff distances:
                          20cm cutoff (more like you get from thea/vray etc)
                          50cm cutoff
                          3m cutoff
                          infinite cutoff
                          • pbacotP Offline
                            Adam,
                            Thanks for the demos. I am not sure what the answer would be as to whether I'd like the results in Lightup. I have to try it again. It looks to me like the AO is too pronounced.
                            Peter
                            • AdamBA Offline
                              AdamB
                              @pbacot said:
                              Adam,
                              Peter
                              Peter, the amount of AO is controllable by a Multiplier, so you can tone it down, change the blend colors, change the blending with direct lights. Lots of control to get the look you want.
                              I turned it up to full whack just so you could see the difference of AO cutoff.
