    LightUp v4.1 released
    extensions
    19 Posts 4 Posters 3.2k Views 4 Watching
      AdamB
      Lots of improvements and features.
      • Realtime scaling of textures
      • Better Fresnel and transparency
      • Faster dispatch
      • Smaller memory
      • Realtime Section Planes on iPad
      Download the latest installer at https://light-up.co.uk
      Support for dynamic Show/Hide of Layers and Objects coming soon.
      http://i614.photobucket.com/albums/tt229/ElektraGlide/apartment_lightupWORKING_640_zps23e95da5.jpg
      • K Offline
        Krisidious
        Installed Demo but don't find lightup anywhere. Where is the default install go?
        By: Kristoff Rand
          driven
          on the mac, it goes into the SU system library 'tools' path for the lowest installed version of SU you have, so v8, v13, ect...
          it adds symlinks to there from any higher versions of SU you have installed...
          it may be similar on windose
          john
          • K Offline
            Krisidious
            I'm on 13 and 14 can't find it in either.
            By: Kristoff Rand
            • K Offline
              Krisidious
              I found it... The default install puts a 'tools' folder inside of "C:\Program Files (x86)"
              Default install should probably pick a typical install location and go with it. Or instruct the user as to what location to choose.
              By: Kristoff Rand
              • K Offline
                Krisidious
                Hmmm... Still not working.
                LightUp is missing files. Please re-install.
                By: Kristoff Rand
                  AdamB
                  Hi Kris,
                  On Windows, the installer checks what version of SketchUp you have and sets up the initial Installation Folder.
                  So if you have SU2014, then it will be set to *C:\Program Files (x86)\SketchUp\SketchUp 2014*
                  If you have SU2013, then it will be set to *C:\Program Files (x86)\SketchUp\SketchUp 2013*
                  and so on. You can of course edit this install location to wherever you like, but the default is based off where you installed SketchUp.
                  Adam
                  • K Offline
                    Krisidious
                    Didn't seem to take on mine. I have both... in Win7. I did choose the location of both 13 and 14 respectively and both seemed to install. But when opening 14 I get the error above and when opening 13 I get a lock. could be a error shown offscreen as I have a funky setup with 4 monitors. But, 2014 gives the error shown above.
                    By: Kristoff Rand
                      AdamB
                      The message you're seeing is because LightUp cannot load its files - aka they're missing.
                      The installer works fine for WinXP,Vista,Win7 and Win8 so it is something to do with your setup.
                      If you open C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools\lightup you will see all the installed files for LightUp: 6 folders and 16 files. Do you see these?
                      Adam
                      • K Offline
                        Krisidious
                        Yes, I see all the files. The toolbar pops up after the error, but nothing happens when I click any of the buttons. Drop down is there.
                        By: Kristoff Rand
                        • P Offline
                          Funny thing with LightUp! β˜€
                          First use this crazzy free MagicaVoxel (Less 20 seconds) then LightUp (1 seconds) ! πŸ˜‰
                          And Random Painter by Chris Fullmer! (in V6 because I am not sure that it's works in 2014! πŸ˜‰
                          MagicaVoxel
                          http://s6.postimg.org/j3r3qqo9d/voxel2.jpg
                          LightUp and of course the true real time without "flickering" in any positions in movement! πŸ˜‰
                          http://s6.postimg.org/j6g1aoy8h/voxel3.jpg
                          http://s6.postimg.org/ygfwhvtqp/voxel4.jpg
                            AdamB
                            Sounds like you have something stamping on your Ruby environment.
                            Open up the Ruby console and type:
                            and it will show where Ruby is looking for plugins.
                            Adam
                            • K Offline
                              Krisidious
                              This is what I get.
                              ["C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib",
                              "C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/platform_specific",
                              "C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools",
                              "C:/Users/Krisidious/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins",
                              "C:/ProgramData/SketchUp/SketchUp 2014/SketchUp/Plugins",
                              "C:/Users/Krisidious/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Gems/gems/uuidtools-2.1.4/lib",
                              "C:/Program Files/Imagination/Visualizer for SketchUp/Windows",
                              "C:/Program Files/Imagination/Visualizer for SketchUp/Scripts"]
                              By: Kristoff Rand
                                AdamB
                                Something strange with your setup. We're seeing many activations this morning around the world.
                                Lets take this offline and figure it out.
                                • K Offline
                                  Krisidious
                                  Sent im... I just upgraded to 2014... Everything has seemed to work ok except SCF Powerbar. I'm sure it's not you. I'm good at messing things up.
                                  By: Kristoff Rand
                                    AdamB
                                    Thanks. So my hunch is that you may have only moved some of the files in the zip download to your Desktop, not ALL of them - hence the installation is missing some files.
                                    Uninstall, open the zip download and copy all of the files and run the installer again.
                                    Adam
                                    • K Offline
                                      Krisidious
                                      If anyone else gets this error you need to look in this location or the 2013 equivalent for the LMapExt2.so file...
                                      C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools\lightup\Extensions\2.0\
                                      By: Kristoff Rand
                                        AdamB
                                        LightUp v4.1c released.
                                        • fixes for group materials
                                        • fixes for Roughness control with IrrCaches
                                        • cleaner incremental render
                                        • updated Chinese & French
                                        • warning if TEMP folder permissions have been broken
                                        Just login, go to Downloads and enter your RegKey at the bottom of the page.
                                        • K Offline
                                          Krisidious
                                          @adamb said:
                                          Hi Kris,
                                          Adam
                                          You might think of adding this as a text description or a tip on the installer. When I install 64bit My system is defaulting to program files 86 base folder. C:\Program Files (x86)\ and no sketchup folder. I have 8, 13, and 14 installed.
                                          By: Kristoff Rand
