    LightUp v4.1 released
    extensions
    19 Posts 4 Posters 3.5k Views 4 Watching
    • KrisidiousK
      Krisidious
      Hmmm... Still not working.
      LightUp is missing files. Please re-install.
      By: Kristoff Rand
      • AdamBA
        AdamB
        Hi Kris,
        On Windows, the installer checks what version of SketchUp you have and sets up the initial Installation Folder.
        So if you have SU2014, then it will be set to *C:\Program Files (x86)\SketchUp\SketchUp 2014*
        If you have SU2013, then it will be set to *C:\Program Files (x86)\SketchUp\SketchUp 2013*
        and so on. You can of course edit this install location to wherever you like, but the default is based off where you installed SketchUp.
        Adam
        • KrisidiousK
          Krisidious
          Didn't seem to take on mine. I have both... in Win7. I did choose the location of both 13 and 14 respectively and both seemed to install. But when opening 14 I get the error above and when opening 13 I get a lock. could be a error shown offscreen as I have a funky setup with 4 monitors. But, 2014 gives the error shown above.
          By: Kristoff Rand
          • AdamBA
            AdamB
            The message you're seeing is because LightUp cannot load its files - aka they're missing.
            The installer works fine for WinXP,Vista,Win7 and Win8 so it is something to do with your setup.
            If you open C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools\lightup you will see all the installed files for LightUp: 6 folders and 16 files. Do you see these?
            Adam
            • KrisidiousK
              Krisidious
              Yes, I see all the files. The toolbar pops up after the error, but nothing happens when I click any of the buttons. Drop down is there.
              By: Kristoff Rand
                Funny thing with LightUp! β˜€
                First use this crazzy free MagicaVoxel (Less 20 seconds) then LightUp (1 seconds) ! πŸ˜‰
                And Random Painter by Chris Fullmer! (in V6 because I am not sure that it's works in 2014! πŸ˜‰
                MagicaVoxel
                http://s6.postimg.org/j3r3qqo9d/voxel2.jpg
                LightUp and of course the true real time without "flickering" in any positions in movement! πŸ˜‰
                http://s6.postimg.org/j6g1aoy8h/voxel3.jpg
                http://s6.postimg.org/ygfwhvtqp/voxel4.jpg
                • AdamBA
                  AdamB
                  Sounds like you have something stamping on your Ruby environment.
                  Open up the Ruby console and type:
                  and it will show where Ruby is looking for plugins.
                  Adam
                  • KrisidiousK
                    Krisidious
                    This is what I get.
                    ["C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib",
                    "C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/platform_specific",
                    "C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools",
                    "C:/Users/Krisidious/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins",
                    "C:/ProgramData/SketchUp/SketchUp 2014/SketchUp/Plugins",
                    "C:/Users/Krisidious/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Gems/gems/uuidtools-2.1.4/lib",
                    "C:/Program Files/Imagination/Visualizer for SketchUp/Windows",
                    "C:/Program Files/Imagination/Visualizer for SketchUp/Scripts"]
                    By: Kristoff Rand
                    • AdamBA
                      AdamB
                      Something strange with your setup. We're seeing many activations this morning around the world.
                      Lets take this offline and figure it out.
                      • KrisidiousK
                        Krisidious
                        Sent im... I just upgraded to 2014... Everything has seemed to work ok except SCF Powerbar. I'm sure it's not you. I'm good at messing things up.
                        By: Kristoff Rand
                        • AdamBA
                          AdamB
                          Thanks. So my hunch is that you may have only moved some of the files in the zip download to your Desktop, not ALL of them - hence the installation is missing some files.
                          Uninstall, open the zip download and copy all of the files and run the installer again.
                          Adam
                          • KrisidiousK
                            Krisidious
                            If anyone else gets this error you need to look in this location or the 2013 equivalent for the LMapExt2.so file...
                            C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools\lightup\Extensions\2.0\
                            By: Kristoff Rand
                            • AdamBA
                              AdamB
                              LightUp v4.1c released.
                              • fixes for group materials
                              • fixes for Roughness control with IrrCaches
                              • cleaner incremental render
                              • updated Chinese & French
                              • warning if TEMP folder permissions have been broken
                              Just login, go to Downloads and enter your RegKey at the bottom of the page.
                              • KrisidiousK
                                Krisidious
                                @adamb said:
                                Hi Kris,
                                Adam
                                You might think of adding this as a text description or a tip on the installer. When I install 64bit My system is defaulting to program files 86 base folder. C:\Program Files (x86)\ and no sketchup folder. I have 8, 13, and 14 installed.
                                By: Kristoff Rand
