    Exploding group removes material from a face
    4 Posts 3 Posters 611 Views 3 Watching
    • G
      gpavlidi
      Hi all,
      I 've encountered this issue where when I am exploding a group, it causes one of the Faces to lose its material, although it doesnt belong in the group.
      Is that an expected behavior, or is this a bug?
      Btw, the reason I am inserting each face, via a group that I explode, is because some of these faces might have holes, and carving out the holes, and then exploding the group is the most robust way I 've found so far that works.
      Thanks,
      Yanis
      Code snippet:
      inner = [[211.304795230314, 59.3387335473855, 144.121274015103], [198.016313479612, 93.8459200290483, 144.121274015103], [198.016313479612, 93.8459200290483, 209.586476052542], [211.304795230314, 59.3387335473855, 209.586476052542]]
      outer_right = [[123.368393800971, 287.689711452616, 222.214015434512], [124.599206984753, 284.49356753989, 222.214015434512], [124.599206984753, 284.49356753989, 7.04087985299685], [123.368393800971, 287.689711452616, 7.04087985299685]]
      outer_bottom = [[123.368393800971, 287.689711452616, 0.0], [123.368393800971, 287.689711452616, 7.04087985299685], [124.599206984753, 284.49356753989, 7.04087985299685], [278.931403899607, -116.27229864223, 7.04087985299685], [280.16221708339, -119.468442554957, 7.04087985299685], [280.16221708339, -119.468442554957, 0.0]]
      outer_left = [[278.931403899616, -116.272298642254, 222.214015434512], [280.16221708339, -119.468442554957, 222.214015434512], [280.16221708339, -119.468442554957, 7.04087985299685], [278.931403899607, -116.27229864223, 7.04087985299685]]
      outer_top = [[121.306929034951, 293.042869957925, 227.414539710024], [201.765305442185, 84.110634448818, 323.731055308166], [282.223681849419, -124.821601060289, 227.414539710024], [282.223681849419, -124.821601060289, 222.214015434512], [280.16221708339, -119.468442554957, 222.214015434512], [278.931403899616, -116.272298642254, 222.214015434512], [278.931403899616, -116.272298642254, 227.414539710024], [201.765305442185, 84.110634448818, 314.768300386351], [124.599206984753, 284.49356753989, 227.414539710024], [124.599206984753, 284.49356753989, 222.214015434512], [123.368393800971, 287.689711452616, 222.214015434512], [121.306929034951, 293.042869957925, 222.214015434512]]
      # place a textured inner face
      temp_group = Sketchup.active_model.entities.add_group
      inner_face = temp_group.entities.add_face inner
      material = Sketchup.active_model.materials.add "Test Material"
      material.color = 'red'
      inner_face.material = material
      temp_group.explode
      # place bounding faces
      outer_right_face = temp_group.entities.add_face outer_right
      temp_group.explode
      outer_bottom_face = temp_group.entities.add_face outer_bottom
      temp_group.explode
      outer_left_face = temp_group.entities.add_face outer_left
      temp_group.explode
      outer_top_face = temp_group.entities.add_face outer_top
      temp_group.explode
      # inner_face has lost it's material
      inner_face.material.nil?
      • S
        slbaumgartner
        I can reproduce this but can't explain it. Seems like a bug to me!
        • G
          gpavlidi
          Thanks slbaumgartner, this is what I thought too.
          Can an admin maybe move this to the 'Report a Bug' subforum?
          Maybe some SU folks out there will notice.
          • TIGT
                temp_group.explode
                temp_group.explode
                temp_group.explode
            	edges=temp_group.entities.grep(Sketchup;;Edge)
                temp_group.explode
            edges.each{|e| e.find_faces if e.valid?}
                temp_group.explode
                ( material = Sketchup.active_model.materials.add("Red") ) unless material=Sketchup.active_model.materials["Red"]
            	material.color="Red"
            	# make 'red' once only
            # inner_face.erase! ### alternative
                puts inner_face.material
            This works.
            It adds a face within the overall form too.
            The 'window' is colored after the explosion.
            Note how I also only make a 'Red' material once.
            You could erase the 'window' instead of making it 'Red'...
            The order of operations and exploding groups affects the result, but knowing that you can avoid it.
