    Error Loading File: toggleWindows.rb
    2 Posts 2 Posters 701 Views 2 Watching
    • S
      Sait Moore
      Has anybody come across this error message? It occurs after SU has initiated, but before I can select any drawing file. If I click on the "OK" radio button in the error message window (there is no other button), the error message window closes and everything proceeds as if nothing happened. That may be an easy work around, but it's gotten rather annoying after a while.
      The full message is:
      Error: #<NameError : unitialized constant PLATFORM>
      c:/USERS/(inserts my User name in the path)/AppData/Roaming/Sketchup/SketchUp2014/Plugins/toggleWindows.rb:4:in '<top (required)>'
      • TIGT
        Your SCF user-profile SketchUp version is not matched by your error-message's version ...
        You probably have an old version of that 'helper' rb installed in v2014....
        In v2014 'togglewindows' is really not needed.
        Although it's included as a helper in some plugins, the latest version should spot it is not compatible with v2014 and therefore abort its loading, and so not cause these errors...
        I suspect you have ill-advisedly just copied some Plugins files over from an earlier version of SketchUp.
        This is NOT recommended !
        Get/install new versions wherever possible...
