    Anatomy of sketchup model
    renderpluginsextensions
    9 Posts 4 Posters 1.0k Views 4 Watching
    • S
      samifox
      I want to create interior and exterior renderings,
      im trying to create my model anatomy correct,
      im modelling 2 story house, here is my workflow,
      i would appreciate any comments,
      do i do it right?
      the picture visualize it,
      if you have time the limed video is all about 3 minutes.
      Shay
      • JonFarJ
        JonFar
        are you serious?...
        if you are, then you should really look up for some sketchup tutorials
        do a search on youtube for tutorials
        there are some good ones, with files included, where they teach how to model a house
        im sure you'll learn the architectural workflow in no time
        • S
          samifox
          @jonfar said:
          are you serious?...
          i think i didnt explain myself,
          i didnt model a house , i just show how ill model in order to avoid v-ray artifacts.
          do you know any tutorial that show what is the right way to model 2 floor house for vray, i would be happy to get the link
          Shay
          • andybotA
            andybot
            you avoid artifacts by modeling everything to scale and avoid overlapping faces. Do you have an example of the artifacts you are trying to avoid?
            • S
              samifox
              actually i just starting now, in some tutorials regarding vray sketchup i saw that there is some guidelines to follow in order to avoid artifacts, i have implemented all in the 3 min clip i posted.
              im modeling the first floor plane, than i model the second floor plan, from the first and the second floor plans i remove faces so they wont overlap when attaching them both, i do attach them together, than i clean the edges, for my understanding i get the perfect model....but i must have the opinion of experienced users.
              Shay
              • JonFarJ
                JonFar
                well...
                all i can say is, i never delete faces from an extruded object like you do...
                and i never seen anyone do that, thats why i was surprised
                just build the model like it would be built in real life and real scale
                use groups and components, and avoid overlaping objects, and you wont get any artifacts...
                edit:
                here you go, a nice youtube tutorial that teaches you an efficient workflow
                1st floor
                http://www.youtube.com/watch?v=SmQIKcJjKUY
                2nd floor
                http://www.youtube.com/watch?v=DQ0mn26shzs
                have fun
                • R
                  rspierenburg
                  Also you can model as you normally would and then use ThomThom's CleanUp plugin to get rid of overlapping faces, orphaned lines etc.
                  • R
                    rspierenburg
                    But to be honest, I've never had an issue with VRAY and overlapping faces (as long as they are grouped). Here is an example I did of a floor assembly. Everything is components and right up against each other. No artifacts.
                    Rob
                    • S
                      samifox
                      Thanks for the tips guys!
                      this video is exactly what ive looked for
                      Thank you
                      Shay
