    Image sampler/antialiasing
    renderpluginsextensions
    6 Posts 4 Posters 758 Views 4 Watching
    • F
      farang013
      hey sketchers..
      i cant get rid of the jigged lines
      any Suggestions??
      • JonFarJ
        JonFar
        i've been looking for this answer myself since i started learning VRay
        and the only sugestion i found till now was to render the image in a bigger resolution and then resize it, but that takes sooooooooooooo much more rendering time... 😢
        i hope someone here has some tips to help us
        • R
          rspierenburg
          Have you tried some the High Quality Interior render Presets?
          • stefanqS
            stefanq
            As you can see, this effect appear only in very bright areas. Be sure to have clamp output and sub-pixel mapping checked. It helps.
            • F
              farang013
              yep....i used one of the preset....
              tanxx all:))
              • JonFarJ
                JonFar
                thanks Stefan, that does the trick for me
