    Dimensions in Sketchup Pro
    4 Posts 2 Posters 317 Views 2 Watching
    • D
      dougscott1
      I can't make the Dimensions stick. When I make the second click for a Dimension, it does not stick the second point of the dimension
        What are you dimensioning? Can you post an example SKP file?
        Is it possible you aren't clicking an end or mid point or something?
        • D
          dougscott1
          I am trying everything, end points, mid points etc. They sometimes work on the first click and on two occasions have worked on the second. But mostly not. How do I attach the file for you in this forum?
            You probably need to get another post under your belt before attaching the file but then below the message window there's a tab labelled Upload Attachment. It should make sense when you look at it.
