    SketchyPhysics 3.5.6 (26 January 2015)
    213 Posts 53 Posters 351.1k Views 53 Watching
    • A
      Anton_S
      @biani patrick said:
      Si ça peut être utile !?
      Thanks for your documentation, patrick. I placed this in first post, as part of reference.
      • A
        Anton_S
        @faust07 said:
        Oh no, Anton I don't want to nerve you. I cheered too soon. A model that ran in SPh3.5.3, jolts in SPh3.5.4 a little ... Probably the steering blocks are squeezed out laterally from the body of the truck. I hope the GIF example shows what a little.
        Is the behavior different in SP3.2? Are you assigning same shapes to SP3.2 and SP3.5.4? Meantime, if they are squeezed out, to fix it, set most surrounding parts and the cabin to Not Collidable.
        • A
          Anton_S
          @faust07 said:
          No, in SP3.2 it did run OK. There were only the other reasons for crashes, you've solved so wonderful! In your SP3.5.3 this truck moved correctly (after resetting some mirrored objects).
          Can you send me the skp model (private message if you prefer), so I could investigate.
          • F
            faust07
            No, in SP3.2 it did run OK. There were only the other reasons for crashes, you've solved so wonderful! In your SP3.5.3 this truck moved correctly (after resetting some mirrored objects in SPh3.5.3).
            • A
              Anton_S
              Where are the physics joints and the wheels? A lot of parts of the model are deleted. Do you mind reuploading? Don't worry about size. You can erase the file from attachments after I download it.
              • F
                faust07
                Here it is. It's a model on the base (not to forget to mention) of posts of Mr.K. and other authors for cars following a path (with little modifications I did, to use it universally). I've blown it up with physical walls, doors, roof, seats, driver, wheels, lights for twilight renderer, euro norm ... Hope, you find a solution.
                Oh sorry, have caught the wrong file. It was too dark last night and there was too much port wine ... I must go to my other computer to upload the correct file.
                • A
                  Anton_S
                  I see what it is. It has nothing to do with the flipped bodies. The problem is that in SP3.5.3 and below the Default shape did not include all geometry as part of collision generation; however, in SP3.5.4 I made it to include all geometry, which I see breaks some compatibility with the prior models. The wheels are pushed out by the lower black part of the cabin which according to Default shape has a box collision. To fix this, you enter the cabin group one level deep, and set the lower black part to ignore:
                  In prior versions, the lower black cabin wasn't even part of collision because the default shape method didn't consider calculating collision for it.
                  I see that you set all sub shapes to not-collidable. Here is the thing to keep in mind. Setting all sub collisions to not-collidable will do nothing. The not-collidable can only be applied to the top groups, not subgroups. Set particular subgroups to Ignore if you don't want them to be part of collision. To remove the not-collidable flag from all subgroups at once, simply select all subgroups of the cabin, right-click and select, SketchyPhysics > State > Collidable.
                  Even though the SP3.5.4 method for default shape is more profound, I will still revert this change to remain compatible with prior models.
                  Edit: Despite that, I just found a bad bug in default shape. I will fix it for SP3.5.5
                  • F
                    faust07
                    I'll change the model accordingly and report briefly. I'm worried that you want to turn back more profound methods for older models.
                    • A
                      Anton_S
                      Okay, fixed it! Now, the default shape should behave like in prior versions. I just adjusted the new method to act like an old one, instead of replacing with the original method from SP3.2. See how it goes!
                      • F
                        faust07
                        Now it works better than ever before. Great! Convexhull2 and compound2 are very usefull shapes too. Thank you again!
                        • F
                          faust07
                          Here it is ...
                          Truck runs with SP3.5.3 & SP3.5.5
                          SketchyPhysics-Truck
                          • J
                            jumpjack
                            Thanks Anton_s for the amazing amount of work you are doing!
                            A couple of notes:
                            Fixed a bug where staticmesh inside a group would force simulation to crash. A staticmesh or compound within the group becomes default shape now.
                            This bug still exists for me using WinXP-SP3, SU 13.0.4812 and SP 3.5.5
                            Added continuous collision checkbox option to the emitter. Enabling this will prevent emitted bodies from passing other bodies at high speeds. Now, bullets will collide if CC is enabled.
                            Where do I find the checkbox?
                            Additionally, a "make hole" function in SP would be amazing and time-saving!
                            • A
                              Anton_S
                              Can you upload a sample model?
                              Open the SketchyPhysics UI, and in the Emitter field, you'll find Emit Continuous Collision Mode checkbox.
                              Do you mean a hole in an object? Like, um, the bullet holes?
                              • V
                                vlkster
                                Any help to get it to run in SU 2015?
                                thanks
                                John
                                • V
                                  vlkster
                                  Also can someone tell me what i'm doing wrong with making my track in SP??
                                  Here is the model
                                  https://www.dropbox.com/s/lwk5a6cl2k60awo/excavator%20tracks.skp?dl=0
                                  John
                                  • J
                                    jumpjack
                                    Do you mean a hole in an object? Like, um, the bullet holes?[/quote]
                                    A hole for a rotating rod.
                                    • A
                                      Anton_S
                                      thanks
                                      John
                                      SketchyPhysics won't work in SU2015 64bit; however, it will work in SU2015 32bit. Its up to Chris Phillips to compile a 64 bit compatible dll and dylib for the the project. I don't have full source to the project.
                                      • A
                                        Anton_S
                                        Each track piece must be divide into groups for proper collision generation. I don't want to go into details, but here is the fixed model. I hope you can figure out what you done wrong with your tracks by comparing them.
                                        excavator_tracks.skp
                                        • V
                                          vlkster
                                          [attachment=0:2xky571h]<!-- ia0 -->excavator_tracks.skp<!-- ia0 -->[/attachment:2xky571h]
                                          Thank you again. Yes i saw what i did wrong with the groups and the connection with the hinges
                                          • J
                                            jbgood
                                            Hope some one can help I have SU 14 pro and just downloaded SketchyPhysics 3.5.5 (October 25 2014) but there does not seem to be any way to install it help anyone please
                                            JBgood
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 6 / 11
