    SketchyPhysics 3.5.6 (26 January 2015)
    213 Posts 53 Posters 345.1k Views 53 Watching
      Anton_S
      I see what it is. It has nothing to do with the flipped bodies. The problem is that in SP3.5.3 and below the Default shape did not include all geometry as part of collision generation; however, in SP3.5.4 I made it to include all geometry, which I see breaks some compatibility with the prior models. The wheels are pushed out by the lower black part of the cabin which according to Default shape has a box collision. To fix this, you enter the cabin group one level deep, and set the lower black part to ignore:
      In prior versions, the lower black cabin wasn't even part of collision because the default shape method didn't consider calculating collision for it.
      I see that you set all sub shapes to not-collidable. Here is the thing to keep in mind. Setting all sub collisions to not-collidable will do nothing. The not-collidable can only be applied to the top groups, not subgroups. Set particular subgroups to Ignore if you don't want them to be part of collision. To remove the not-collidable flag from all subgroups at once, simply select all subgroups of the cabin, right-click and select, SketchyPhysics > State > Collidable.
      Even though the SP3.5.4 method for default shape is more profound, I will still revert this change to remain compatible with prior models.
      Edit: Despite that, I just found a bad bug in default shape. I will fix it for SP3.5.5
      • F
        faust07
        I'll change the model accordingly and report briefly. I'm worried that you want to turn back more profound methods for older models.
          Anton_S
          Okay, fixed it! Now, the default shape should behave like in prior versions. I just adjusted the new method to act like an old one, instead of replacing with the original method from SP3.2. See how it goes!
          • F
            faust07
            Now it works better than ever before. Great! Convexhull2 and compound2 are very usefull shapes too. Thank you again!
            • F
              faust07
              Here it is ...
              Truck runs with SP3.5.3 & SP3.5.5
              SketchyPhysics-Truck
                jumpjack
                Thanks Anton_s for the amazing amount of work you are doing!
                A couple of notes:
                Fixed a bug where staticmesh inside a group would force simulation to crash. A staticmesh or compound within the group becomes default shape now.
                This bug still exists for me using WinXP-SP3, SU 13.0.4812 and SP 3.5.5
                Added continuous collision checkbox option to the emitter. Enabling this will prevent emitted bodies from passing other bodies at high speeds. Now, bullets will collide if CC is enabled.
                Where do I find the checkbox?
                Additionally, a "make hole" function in SP would be amazing and time-saving!
                  Anton_S
                  Can you upload a sample model?
                  Open the SketchyPhysics UI, and in the Emitter field, you'll find Emit Continuous Collision Mode checkbox.
                  Do you mean a hole in an object? Like, um, the bullet holes?
                  • V
                    vlkster
                    Any help to get it to run in SU 2015?
                    thanks
                    John
                    • V
                      vlkster
                      Also can someone tell me what i'm doing wrong with making my track in SP??
                      Here is the model
                      https://www.dropbox.com/s/lwk5a6cl2k60awo/excavator%20tracks.skp?dl=0
                      John
                        jumpjack
                        Do you mean a hole in an object? Like, um, the bullet holes?[/quote]
                        A hole for a rotating rod.
                          Anton_S
                          thanks
                          John
                          SketchyPhysics won't work in SU2015 64bit; however, it will work in SU2015 32bit. Its up to Chris Phillips to compile a 64 bit compatible dll and dylib for the the project. I don't have full source to the project.
                            Anton_S
                            Each track piece must be divide into groups for proper collision generation. I don't want to go into details, but here is the fixed model. I hope you can figure out what you done wrong with your tracks by comparing them.
                            excavator_tracks.skp
                            • V
                              vlkster
                              [attachment=0:2xky571h]<!-- ia0 -->excavator_tracks.skp<!-- ia0 -->[/attachment:2xky571h]
                              Thank you again. Yes i saw what i did wrong with the groups and the connection with the hinges
                                jbgood
                                Hope some one can help I have SU 14 pro and just downloaded SketchyPhysics 3.5.5 (October 25 2014) but there does not seem to be any way to install it help anyone please
                                JBgood
                                • cottyC
                                  cotty
                                  @jbgood said:
                                  JBgood
                                  There are several ways to install plugins in 2014, which one did you choose?
                                  my SketchUp gallery
                                    Anton_S
                                    @jbgood said:
                                    JBgood
                                    You may also refer to this post, I'll add it part of main description:
                                    http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=58936%26amp;start=30#p540351
                                      deskpilot
                                      May I jump in on this thread gents. I've recently purchased a new pc,loaded SU2014Make and SP3.5.5.. Kept getting that annoying warning about a bad install so I went back a step and loaded an earlier version, 3.1. Now, full install seems OK but the plugin is permanently disabled. Try as I might, I can't get it to do anything but say it will be disabled next time I fire up my pc. Any answers please. If I have to go into DOS or similar, please explain all steps.
                                        Anton_S
                                        Hello,
                                        It would be nice if you provide me some more details.
                                        • What warning message do you get?
                                        • What operating system are you using?
                                          Regardless of that, I don't think SketchyPhysics 3.1 will work in SU2013 or above. Keeping it in the 2014 plugins folder is useless. I suggest you to go to C:\Users\YOUR_NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins, and erase all sketchy physics versions from the folder. Then, download the SP3.5.5 if you hanven't so, and extract content into the plugins folder. It should look like this:
                                          *...\Plugins*
                                        • SketchyPhysics3
                                        • SketchyPhysics.rb
                                        Hope this helps or provide some details if you can't get it working.
                                          deskpilot
                                          OK, done as you suggested but now I'm back to:
                                          Loading error
                                          Error Loading File sketchyphysics.rb
                                          Error: #<LoadError: cannot load such file -- SketchyPhysics3/ClassExtensions.rb>
                                          C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sketchyphysics.rb:19:in load' C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sketchyphysics.rb:19:in LoadSketchyPhysics3'
                                          C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sketchyphysics.rb:61:in doLoad' C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/sketchyphysics.rb:137:in <top (required)>'
                                          Would appreciate next step
                                          Cheers, Doug aka Deskpilot
                                          PS, running Windows 7 Home on a 64 bit systems
                                            Anton_S
                                            That file is from old sketchyphysics version. It seems you didn't delete sketchyphysics.rb from the plugins folder as i suggested in previous post.
                                            • 11
                                            • 6 / 11
