    Any help with this would be appreciated
    3 Posts 3 Posters 208 Views 3 Watching
      rjsutton
      Hi Guys
      I have had a few problems with this model I have completely redrwn it BUT can get one piece to erase....
      I need the bottom of the curved shape to erase so you can see right thru the model. Have tried moving-shifting -everything i can think of
      Any help please
      thanks in anticipation
      Richard
      the model is "part needed bottom cleared" i have attached another drawing of the finished part ( but has major faults but it shows the Hole i need )
      part needed bottom cleared.skp
      part b for info only.skp
      • cottyC Offline
        cotty
        The edges of the desired face are not coplanar, I've corrected them...
        e.g.
        part needed bottom cleared_b.skp
        my SketchUp gallery
        • ely862meE Offline
          ely862me
          Cotty,where was that?(Edit-Obviously in the sight!) I made the edges coplanar, put it didn't closed. (Edit I have had another go on it, and it worked ...)
          I wonder sometimes, how can one achieve such a faulty model.
          Since there are some other open faces that won't close I would advice you to remodel the part entirely. Since it is a symmetric model, I would use follow me tool to recreate it.
          Elisei (sketchupper)
          Come and See EliseiDesign
