Any help with this would be appreciated
Hi Guys
I have had a few problems with this model I have completely redrwn it BUT can get one piece to erase....
I need the bottom of the curved shape to erase so you can see right thru the model. Have tried moving-shifting -everything i can think of
Any help please
thanks in anticipation
Richardthe model is "part needed bottom cleared" i have attached another drawing of the finished part ( but has major faults but it shows the Hole i need )
part needed bottom cleared.skp
The edges of the desired face are not coplanar, I've corrected them...
e.g.
Cotty,where was that?(Edit-Obviously in the sight!) I made the edges coplanar, put it didn't closed. (Edit I have had another go on it, and it worked ...)
I wonder sometimes, how can one achieve such a faulty model.
Since there are some other open faces that won't close I would advice you to remodel the part entirely. Since it is a symmetric model, I would use follow me tool to recreate it.
