    How shoulid i to extend with more than 4 edges
    4 Posts 4 Posters 417 Views 4 Watching
    • Y Offline
      YoungOSG
      just like the pictures.
      the face has 6 edges.and i want to extend it to fill up the gap with the top faces.
      the problem is there are 3 faces ,and i need to extend the face to them ,make sure there are no gaps any mnore.
      is there any plugins to do this ?
      thanks for help!
        It's difficult to see exactly what it is you've got going on without the model. The point of view is not helpful.
        Maybe just draw lines between corresponding corners. If there are still holes, draw diagonals. There may be other ways but without seeing the model, it's probably pointless to suggest.
        Learn to use the native tools instead of immediately looking for a plugin.
        • cottyC Offline
          cotty
          There are plugins for such a task (e. g. Extrude Edges By Vector To Object), BUT as Dave suggested, this seems not a problem for which a beginner should search for a plugin (the correct selection of the edges and the exploration of the plugin will take longer than drawing some lines with the line tool).
          my SketchUp gallery
          • mitcorbM Offline
            mitcorb
            or, to make a discrete selection and use the move tool
