    Cutlist settings
    2 Posts 2 Posters 359 Views 2 Watching
    • zain01Z Offline
      zain01
      Hey everyone
      I am trying to use cutlist and its displaying my parts limited to the width of a board instead of a sheet
      ergo all my carcass sides which should be 600mm deep are only 200mm deep.
      Is there a way of turning off the board option and only using the sheet function?
      Thanks in advance
        Add a sheet material word to the component definition name. i.e. MDF, sheet, plywood, etc. Or add a new sheet material word that your components already use such as 'panel' in the first page of the CutList UI. Remember to save the settings. Or you can add a material to the components which has a sheet material word in its name. You can modify a simple color's name if you don't want to have actual materials applied.
        Any of those options will get the parts to show up in the Sheet Materials section instead of the solid wood components section.
