    Failed exporting to STL - any suggestions?
    3 Posts 3 Posters 7.6k Views 3 Watching
    • K
      keknor
      annex stikk for 3D print1 for STL.skpHello
      I have made a quite simple drawing in Sketchup 8 pro for 3D printing. Sketchup Tools/outer shell tells me it is a Solid Component. The plugin Tools/Solid Inspector find no faults. I have aplied Soften Edges. Circles are 24 segments. All faces are checked and are pointing outwards. I find no stray lines inside (using x-ray. All are layer 0 and Materials are Default. I have installed the export STL plugin ver. 2.1.4 from Sketchup
      Still it will not export to STL.
      • dukejazzD
        dukejazz
        Hi Keknor
        Your model is ok
        Your STL exporter out of date
        You have 2 option
        save and reload to a 2013 file
        or
        update Your STL exporter 2014
        I tried both way and it save the STL file
        it should work for you.
        PS - I had the same issue I saw what you saw now it fixed. Now STL converter can be found in the file menu instead of plug-ins menu
        happy computing
        • D
          d12dozr
          keknor, did dukejazz's suggestions help you? You may have to type the file extension [.stl] at the end of the filename after you export it, since the exporter doesn't always do that automatically.
          http://goo.gl/f7ooYh
