    Problems with installing plugins
    2 Posts 2 Posters 1.0k Views 2 Watching
    • jo-keJ
      jo-ke
      On an additional machine I upgraded now to SU2014 but I am having some problems installing some plugins via SU Pluginstore:
      Can anybody help me to fix that?
      Fehler beim Laden der Datei bezierspline.rb
      Error: C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/bezierspline.rb:49: invalid multibyte char (UTF-8)
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/bezierspline.rb:49: syntax error, unexpected tCONSTANT, expecting keyword_end
      ext.copyright = "Fredo6 - \© Sep. 2007 - Dec. 2008"
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/bezierspline.rb:49: syntax error, unexpected tINTEGER, expecting '('
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/bezierspline.rb:49: unterminated string meets end of file
      Error: c:/users/kehlj.dor/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/dm_artisan/artisan.rbs:273: invalid multibyte char (UTF-8)
      c:/users/kehlj.dor/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/dm_artisan/artisan.rbs:273: syntax error, unexpected end-of-input, expecting keyword_end
      data="90¡M5lªÙ[:}¶šä^Ÿ-Ú¢ßÓjt@+¡©t›p}x±" #just garbage
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DM_artisan/artisan_load.rb:10:in `eval'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DM_artisan/artisan_load.rb:10:in `load'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DM_artisan/artisan_load.rb:10:in `module:Artisan'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DM_artisan/artisan_load.rb:3:in `module:DM'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DM_artisan/artisan_load.rb:1:in `<top (required)>'
      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `require'
      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `load'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DM_artisan.rb:18:in `register_extension'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DM_artisan.rb:18:in `module:Artisan'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DM_artisan.rb:5:in `module:DM'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DM_artisan.rb:4:in `<top (required)>'
      Fehler beim Laden der Datei jointpushpull.rb
      Error: C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jointpushpull.rb:52: invalid multibyte char (UTF-8)
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jointpushpull.rb:52: syntax error, unexpected tINTEGER, expecting keyword_end
      ext.copyright = @@creator + " - \© 2008-2011"
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jointpushpull.rb:52: syntax error, unexpected tSTRING_BEG, expecting keyword_end
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jointpushpull.rb:52: unterminated string meets end of file
      Fehler beim Laden der Datei LibFredo6.rb
      Error: C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/LibTraductor.rb:33: invalid multibyte char (UTF-8)
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/LibTraductor.rb:33: syntax error, unexpected tIDENTIFIER, expecting ']'
      "|ES| Los siguientes Par\ámetros son inv\álidos"]
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/LibTraductor.rb:33: syntax error, unexpected $undefined
      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/LibFredo6.rb:26:in `<top (required)>'
      Fehler beim Laden der Datei LibTraductor.rb
      Fehler beim Laden der Datei C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/debug.rb
      Error: #<LoadError: 126: Das angegebene Modul wurde nicht gefunden. - C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/libraries/win32/tt_api.so>
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/win32.rb:16:in <module:Win32>' C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/win32.rb:12:in <top (required)>'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/debug.rb:10:in <top (required)>' C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:432:in require'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:432:in block in <top (required)>' C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:431:in each'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:431:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_cleanup.rb:89:in <top (required)>'
      Fehler beim Laden der Datei C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/win32.rb
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:432:in require' C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:432:in block in <top (required)>'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:431:in each' C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:431:in <top (required)>'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_cleanup.rb:89:in <top (required)>' Fehler beim Laden der Datei tt_quadface.rb Error: #<SyntaxError: C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_quadface.rb:57: unknown regexp options - btbckt C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_quadface.rb:57: unterminated string meets end of file C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_quadface.rb:57: syntax error, unexpected end-of-input, expecting keyword_end ...------------------------------- ... ^> Error: #<LoadError: 126: Das angegebene Modul wurde nicht gefunden. - C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Vertex/CExt/win32/VT_CEXT.so> C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' c:/users/kehlj.dor/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/tt_vertex/core.rbs:22:in <main>'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Vertex/loader.rb:10:in eval' C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Vertex/loader.rb:10:in require'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Vertex/loader.rb:10:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Vertex.rb:76:in register_extension'
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Vertex.rb:76:in <module:TT_Vertex>' C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Vertex.rb:23:in <top (required)>'
      Fehler beim Laden der Datei ZLoader__FredoScale.rb
      Error: C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__FredoScale.rb:32: invalid multibyte char (UTF-8)
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__FredoScale.rb:32: syntax error, unexpected tIDENTIFIER, expecting keyword_end
      text = "Problème avec l'installation du plugin #{fro6__plugin}"
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__FredoScale.rb:33: syntax error, unexpected tIDENTIFIER, expecting keyword_end
      text += "\nLibFredo6 n'est pas install\é ou bien n'est ...
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__FredoScale.rb:33: syntax error, unexpected $undefined
      ..."\nLibFredo6 n'est pas install\é ou bien n'est pas dans le b...
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__FredoScale.rb:33: invalid multibyte char (UTF-8)
      Fehler beim Laden der Datei ZLoader__OnSurface.rb
      Error: C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__OnSurface.rb:34: invalid multibyte char (UTF-8)
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__OnSurface.rb:34: syntax error, unexpected tIDENTIFIER, expecting keyword_end
      text = "Probl\ème avec l'installation du plugin #{fro6__plugin}"
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__OnSurface.rb:35: syntax error, unexpected tIDENTIFIER, expecting keyword_end
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__OnSurface.rb:35: syntax error, unexpected $undefined
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__OnSurface.rb:35: invalid multibyte char (UTF-8)
      Fehler beim Laden der Datei ZLoader__RoundCorner.rb
      Error: C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__RoundCorner.rb:32: invalid multibyte char (UTF-8)
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__RoundCorner.rb:32: syntax error, unexpected tIDENTIFIER, expecting keyword_end
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__RoundCorner.rb:33: syntax error, unexpected tIDENTIFIER, expecting keyword_end
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__RoundCorner.rb:33: syntax error, unexpected $undefined
      C:/Users/kehlj.dor/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__RoundCorner.rb:33: invalid multibyte char (UTF-8)
      Fehler beim Laden der Datei Fredo6_!LibFredo6.rb
      C:/ProgramData/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:29:in `<top (required)>'
      http://www.zz7.de
        Did you just copy the plugins over from an older SketchUp installation? If so, go into the Plugins folder and delete the files related to them and install freshly downloaded version.
        It looks like you need to get fresh copies of:
        bezierspline
        artisan
        joint push/pull
        LibFredo6
        TT_Lib2
        Vertex Tools
        FredoScale
