    SketchUp 2014 Load Error Message
    3 Posts 2 Posters 773 Views 2 Watching
    • J
      James Hookway A7
      Hi there,
      I just recently tried to install a "Point Cloud Triangulation" plugin for Sketchup.
      I originally installed one that didn't work. it was simply called "points_cloud_triangulation.rb".
      I removed the .rb file from my SketchUp and tried a different one, "TIG_points_cloud_triangulation.rb". This one worked great for me.
      Now though, rather annoyingly, every time I open SketchUp I am greeted with this message...
      %(#FF0000)[Error Loading File points_cloud_triangulation.rb
      Error: #<LoadError: cannot load such file -- delaunay2.rb>
      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require'
      C:/Users/JamesH/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/points_cloud_triangulation.rb:21:in `<top (required)>']
      I have tried reinstalling SketchUp and all but I just can't get rid of this error message. It's strange, as this is the Plugin I removed earlier, but it is still giving me error messages for me. i just can't figure out how to disable it altogether. Very surprised a clean install didn't solve this.
      Any suggestions?
      Cheers.
      • S
        slbaumgartner
        @james hookway a7 said:
        Hi there,
        Any suggestions?
        Cheers.
        That last line in the message would seem to be your clue: SketchUp is still trying to load points_cloud_triangulation.rb from C:/Users/JamesH/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins. Take a look there and delete the file.
        A fresh installation only overwrites the contents in the application's own folders, it does not erase or overwrite your per-user plugins.
        • J
          James Hookway A7
          That did it! Thanks a lot for the heads up. I didn't realise Sketchup had made a secondary folder elsewhere. Noted for next time!
          Cheers.
