    SCF plugin store load error
    2 Posts 2 Posters 552 Views 2 Watching
    • W
      waekai
      I get this when I launch SU.
      I have SU 2014 pro and the latest version of SCF plugin store.
      Windows 7.
      [code][/Error: #<LoadError: cannot load such file -- open-uri>
      c:/users/31smb/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:76:in `require'
      c:/users/31smb/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:76:in `module:SCFapi'
      c:/users/31smb/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/sketchucation/!scfapitools.rbs:22:in `<main>'
      C:/Users/31smb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in `eval'
      C:/Users/31smb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in `load'
      C:/Users/31smb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:25:in `block in <top (required)>'
      C:/Users/31smb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:14:in `each'
      C:/Users/31smb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchUcation/SCF_loader.rb:14:in `<top (required)>'
      C:/PROGRA~2/SketchUp/SKETCH~1/Tools/extensions.rb:197:in `require'
      C:/PROGRA~2/SketchUp/SKETCH~1/Tools/extensions.rb:197:in `load'
      C:/Users/31smb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:189:in `register_extension'
      C:/Users/31smb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:189:in `module:SCF'
      C:/Users/31smb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/!SketchUcation_loader.rb:16:in `<top (required)>'code]
      • TIGT
        This is a known issue which can afflict v2014 M0 PC users.
        It can happen with any plugin that trying to access the latest Ruby2 functions - IF you start SketchUp by opening a SKP which is on a drive other than where the SketchUp.exe file is located [usually C:].
        To see this open SketchUp as an application ans then open the SKP = NO error.
        What happens is that SketchUp mis-makes the $: as it starts, and looks for the Ruby2 files on the SKP's drive NOT the .exe's drive, it can't find them, and there's the error message...
        Now for the good news... β˜€
        A temporary fix named !_fix_ruby_startup2-1-2.rb was developed, this went into the Tools folder and as it loaded it rewrote the $: properly. You could get it and its instructions by Searching on SCF...
        BUT v2014 M1 was released a few weeks ago and that no longer displays this problem πŸ˜„
        See http://www.sketchup.com/download/all
        So I recommend you update to the appropriate PC version from there...
