    Change Color of ->Selected<- Dimensions?
    2 Posts 1 Posters 377 Views 1 Watching
    • K
      Kanastrous
      Hey -
      I know that the color of dimension lines and text may be set via the Entity Info panel, but what I want to change is the color to which they -change- when selected. Working against a white background and having one's dimensions change to bright yellow when selected is...problematic.
      Read through the threads on dimension-line color selection here and they only deal with the un-selected color - didn't find word on how to change the color to which they change when selected.
      Typically most files with which I work have black lines and text that change to blue when selected. Knowing how to set that change-to-blue instead of the change-to-yellow with which some files load up would be wonderful.
      Thanks in advance for any suggestions.
      • K
        Kanastrous
        Found it. In case anyone else wonders it's accessed via the Styles Panel: Edit->Modeling (furthest tab to the right).
