    Active_view.camera.get_center2d & .get_scale2d
    3 Posts 2 Posters 376 Views 2 Watching
      tomasz
      I can read center2d and scale2d of a page camera through C++ SDK.
      Is there any chance I could get those values for active_view.camera?
      The active camera in C++ SDK is not being updated when SU view is modified (inside SketchUp).
      If it is not possible, then I kindly request this feature in Ruby API.
      Reading camera.field_of_view_is_height would be also good to have.
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        Can't you just use:
        Sketchup.active_model.active_view.vpwidth and .vheight to get the model window's pixel size, then take half of those to get the center point relative to top-left corner of the window ?
          tomasz
          get_center2d() and get_scale2d() C++ SDK functions return a camera shift and zoom-in factor for 2p perspective camera.
          You reply gave me idea, that maybe I could calculate the shift/zoom using InputPoint.position... This may work.
