    Having trouble colouring lines
    4 Posts 4 Posters 378 Views 4 Watching
    • X
      x1l3nt
      To color lines I've been using Window > Styles > edit > edges > color set to by material and then using the paint bucket tool but for some reason this is no longer working for me, I must have changed a setting or something, help would be appreciated thanks!
      • deaneauD
        deaneau
        i have never try to change the lines with the paint bucket however this works in 2013.
        you can try color edge
        http://sketchucation.com/forums/viewtopic.php?p=251619#p251619
        dean
        MADE, BORN AND LIVING IN BERLIN
        Big Thank You to all Programmers
        Some German words are so long that they have a perspective. M.Twain
        • cottyC
          cotty
          Do you have an example file? It should would that way...
          my SketchUp gallery
          • Wo3DanW
            Wo3Dan
            You may have changed scenes to one that hasn't "by material" saved. So edges are black again without noticing that you changed back the style to "edges color all the same".
