    Unextrude object
    3 Posts 3 Posters 505 Views 3 Watching
    • W
      Warren Rempel
      I have created a large number of walls in 3D, which I need to convert back to 2D images. When I use the extrude tool to reduce them down, the wall disappears. Obviously, this is great if you're undoing walls, but I want to reduce the height to 'zero', while retaining the outline in plan. Is there a way to do this?
        The easiest way I know of would be to use Select to select everything above the bottom of the walls. Then hit the Delete key. A right to left selection box dragged across the walls, making sure to avoid the bottom should take care of it.
        • BoxB
          Also depending on your structure and the actual results you want you could use a section plane or change the view to top and use parallel projection.
