    Imposible to install INSTANT ROOF in SU 2014
    8 Posts 6 Posters 4.6k Views 6 Watching
      jeimious
      Hi!
      I´m new at the forum.
      I was looking for it to try to solve my problem but I don´t found anything.
      I was downloaded INSTANT ROOF plugin, and I was trying to put it in my SU 2014 but I can´t. It´s a .rbs file.
      I tried to copy it in plugins folder but it doesn´t work.
      Someone can help me?
      Thanks a lot!
        Well, it isn't "imposible" to install it. It sounds like you've installed it incorrectly. On the other hand, if you read the authors webpage on Instant Roof you'd have seen the comment in red which might have given you a clue.
        Instant Roof NUI is compatible with SU2014, though.
        • KrisidiousK Offline
          Krisidious
          I think there is a new Instant Roof 'Nui' for 2014.
          Doh. didn't see Dave's text below screen grab.
          By: Kristoff Rand
          • pbacotP Offline
            If you actually tried Instant Roof "Nui" AND are still having problems, it may have to do with following the general plugin installation procedures correctly. If you still have trouble, describe what you did and what you now see (or how do you know it is not right).
            Also the plugin's author is quite helpful, but he shouldn't be bother perhaps, explaining how to install plugins. Better to contact him if you can't figure out a specific plugin issue after much study.
            • sfto1S Offline
              sfto1
              I had similar issues with Instant Roof Pro. The author in private message indicated he was not going to address compatibility issue with 2014. Instead, I believe he is solving the issue with a subscription based plugin leaving his pro purchasers having to use SU2013 or earlier. Found this out with less than a year of using Instant Roof Pro. Great Plugin, but lousy support.
                Krisidious
                Well the Nui isn't just Instant Roof, it comes with toolbar, visual examples in UI, framing, new styles and 2014 compatibility. But, yes I hate subscriptions.
                By: Kristoff Rand
                  jeimious
                  Thanks Dave R, I didn´t see it.
                  • G Offline
                    gmcl
                    I downloaded instantroof in rbs format. Im using SU pro 2018, it wants to load rbz files only in my extension manager. Can someone also pls confirm if the instantroof rbs file is somewhat close to 3.5mb
                    It would be handy if a willing heart can explain the steps involve in installing instantroof rbs file.
                    Cheers
