    How to get current active axis?
    9 Posts 6 Posters 909 Views 6 Watching
    • PixeroP
      Pixero
      As the title says. How do I get the current active axis?
      • jolranJ
        jolran
        Tjena.
        Let say you get a face normal called new_z.
        You could say new_z is the upvector, if I remember correctly.
        Anyway. new_z must be a vector. That you use as current Z-axis.
        x_axez, y_axez, z_axez = new_z.axes
        • PixeroP
          Pixero
          Tjena!
          [Off Topic Swedish: Har du sett att vi startat ett svensk subforum? Gå in under dina inställningar och lägg till om du vill se det.]
          I should have been clearer, I'd like to get the axis of the current component beeng selected.
          • TIGT
            Use component_instance.transformation.origin to get its location in its container and then
            component_instance.transformation.zaxis etc for the axes...
            See here: http://www.sketchup.com/intl/en/developer/docs/ourdoc/transformation
            These API notes are full of typos 😒 , BUT you should get the gist... 🤓
            • jolranJ
              jolran
              OT
              Nej! Ska genast kolla. Tack 😄
              Do you mean the Transformation.origin ?
              I mean it depends on how the component is built ?
              It could be a gluing component or face me.
              You could check out this topic.
              http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=57623%26amp;p=524693%26amp;hilit=get+component#p524693
              Edit TIG was faster.
              • PixeroP
                Pixero
                Oooh, I feel rusty.
                And if I want to use this within a selection. Check to see if it's a group or component and get axis and if it's not, use world axis? or parents axis if that is a component.
                Am I making sense?
                • AdamBA
                  AdamB
                  In general, to get the worldspace axes, you'll need to chase up the hierarchy to the top, applying each parent.
                  Its kind of a pain..
                  • T
                    tomasz
                    To get the current hierarchy you can use:
                    path=Sketchup.active_model.active_path
                    http://www.sketchup.com/intl/en/developer/docs/ourdoc/model#active_path
                    • tt_suT
                      tt_su
                      If you are in the root context then you can't. If the user has set a custom axis then there is no Ruby API method to obtain that. We have that logged as a feature request.
