    64bit Distributed rendering and Vray lights Problem
    renderpluginsextensions
    2 Posts 2 Posters 530 Views 2 Watching
      rajab0v
      Hello There All, its my first Topic Here And I really need Help !
      I noticed That Vray Isn't rendering lights when using 64 Distributed Rendering, And If it do, it will render 4 lights as a maximum number, while it renders it normaly when 64 bit distributed is off, any solution for this problem Please ?
        rspierenburg
        I believe the 4 light restriction is due to you using the Demo version of the software. If you upgrade to the full version that should go away.
        Rob
